vfs.dir.count - Invalid parameter
  • grefabu
    • Jul 2019
    • 45
    I've a syntax problem when I define a new item. I try vfs.dir.count, I think I use it like the help:
    vfs.dir.count[/dev] #monitors the number of devices in /dev (Linux)
    vfs.dir.count["C:\Users\ADMINI~1\AppData\Local\Temp"] #monitors the number of files in a temporary directory
    Here my example:
    vfs.dir.count["C:\inetpub\logs\LogFiles"]
    But I get:
    When I use single quotation marks I could save the item: vfs.dir.count['C:\inetpub\logs\LogFiles\']
    But I always get zero as value.
    I could use a userparamter in the Zabbix conf to make it with an powershell script, but I hope it is possible to use the buildin function?
    Bye
    Gregor
  • Answer selected by Markku at 03-07-2025, 15:21.
    Markku
    • Sep 2018
    • 1784
    Remove the trailing backslash from the path.
    Markku
    • Markku
      • Sep 2018
      • 1784
      Markku
      • grefabu
        • Jul 2019
        • 45
        Life could be so easy ;-)
