Help w Large-scale bandwidth monitoring
  • lucassalaroli
    • Jul 2025
    Hello everyone!
    I am currently working on an infrastructure that handles hundreds of servers from different sources.
    One of the tasks I am researching to optimize observability is about the bandwidth consumption of each server.
    Could you share with me the best way to perform this monitoring in Zabbix so that I can monitor daily and monthly consumption?
    A PLUS would be the possibility of calculating the start and end of the monthly cycle based on the date that the bandwidth package of my cloud servers is renewed.
    Any help is welcome!
  • PavelZ
    • Dec 2024
    • 172
    These are standard templates for Linux and Windows. Items are called something like this: Interface ...: Bits received
    What is the problem? What do you expect to find?
    • pyritejoe
      • Aug 2022
      • 15
      Are looking for something like this?
      • PavelZ
        • Dec 2024
        • 172
        I'm afraid it's not that easy to do.
        How about using a script like this https://github.com/tim-reslv/zabbix-excel-report ?
        Grafana also has options for aggregation performed on the front-end
        • PavelZ
          • Dec 2024
          • 172
          Hi , lucassalaroli , pyritejoe
          To collect such data you need a rather unusual expression and rather complex calculations :
          trendsum(//net.if.in["eth0"],1M:now/M+1M)
          However, if you use special functions for trends, everything works quite well.
          I suggest everyone to test this template https://github.com/pavlozt/somezabbi...onthly-traffic
          • pyritejoe
            • Aug 2022
            • 15
            Checking this out as I type, and will let you know what I get.
