Hey,
I'm using Zabbix 3.2.6, and I've set up the zabbix agent on a remote server.
It is reporting things like CPU, MEM, Disk space but network traffic I/O is at 0bytes - and has been ever since the agent has been running.
Is there something I am missing? It is looking on eth0 which i can confirm is the correct, do I need to set up
The agent is running on Ubuntu 14.04
I'm using the default item which i think comes bundled in the Linux OS template:
Any help is appreciated
EDIT:
We have GRS, the agent needed elevated privileges to capture network data.
EDIT:
