'Trigger overview' is not showing me Alarms.
  • majster
    • May 2020
    • 12
    Hello folks!
    I have a Zabbix 6.4 based on Ubuntu 22.04 . Few days ago I've created new dashboard to see which URL webcheck. It was working fine for a day or two, then it stopped showing me any content.
    I can see problems under configuration pane
    but under Monitoring/Problems no
    ​And dashboard widget is empty
    ​I've checked the formulas but they weren't changed (I think), I've upgraded Ubuntu packages, rebooted the server but these simple approaches did not helped.
    What am I missing here?
  • tim.mooney
    • Dec 2012
    • 1436
    What happens if you click Show: "History" in Monitoring->Problems?
    Does that change anything?
    • majster
      • May 2020
      • 12
      Good question. It shows problems as resolved. So there must be some kind of an issue with formula then. Is there a way to test formulas?
