Execute Zabbix script items outside of Zabbix
  • troffasky
    • Jul 2008
    • 639
    I am trying to write a template using Zabbix Script item to talk to Sonicwall SonicOS API.
    Is there a way I can execute the script outside of Zabbix for development/testing purposes? Obviously it would have to execute it exactly as Zabbix does in order to be useful.
  • PavelZ
    • Dec 2024
    • 172
    There is such a utility
    You can install it the same way as regular packages. The package is called zabbix-js
    • troffasky
      • Jul 2008
      • 639
      Thankyou. Would be great if this was linked from the "Script items" documentation.
      • troffasky
        • Jul 2008
        • 639
        Any idea what the input file format is? The man page just says "the input parameter". I am guessing this would provide "obj".
        • troffasky
          • Jul 2008
          • 639
          I tried looking at zabbix_js.c but could not work this out.
          All Hail our New AI Overlords....I asked Deepseek and it told me:
          The zabbix_js tool (used for testing Zabbix JavaScript preprocessing scripts) expects the -i parameter to accept input data in JSON format. This input simulates the data passed to the preprocessing script during runtime.
          Example:
          bash
          zabbix_js -s script.js -i '{"key1":"value1", "key2":123}'​
          And it's actually correct! It's not perfect - it hallucinated a "-I" parameter that doesn't exist. But the main thing is, I have this working, so I am happy.
