Permission issues in the dashboard – Host Navigator & Host Item
  • danielitm
    • Mar 2025
    • 28
    Hello everyone,
    I've recently encountered a problem with permissions in the Zabbix dashboard and wanted to ask if anyone has had similar experiences or knows a solution.
    Setup:
    - Zabbix version: 7.4.0
    - Dashboard with the following widgets:
    - Host Navigator
    - Widgets with Host Items where a host from the Host Navigator is adopted via "Override host"
    Problem:
    A user is authorized for a specific host group and correctly sees the hosts they have access to in the Host Navigator. However, as soon as a widget on the dashboard uses a **Host Item** that doesn't belong to a host the user is directly authorized for, the widget remains empty—**even if the host was selected via the Host Navigator**.
    Observation:
    Permissions appear to come **exclusively** from the Host Item configured in the widget. The Host Navigator is **not considered**, which significantly limits dashboard flexibility for restricted users.
    Goal:
    I wanted to build a dashboard for multiple users/groups where they only see the servers they're authorized to access.
  • danielitm
    • Mar 2025
    • 28
    Zabbix version: 7.4.1 still has the same problem
    • kz3
      • Jul 2025
      • 20
      First I would create the users (User1, User2, User3),
      each one allowed to see only one host group. Then I would create a user role for dashboards, with access only to Dashboards and Problems but keeping access to all widgets.
      After that, I would create user groups and assign the corresponding host group permissions (for example, a group called VMware containing User1, with only the host groups User1 is allowed to see).
      I would repeat the same for the other users.
      Finally, I would create a dashboard with widgets including all host groups.
      When any user logs in, they will only see the data belonging to their allowed host groups.
      • danielitm
        • Mar 2025
        • 28
        Thanks for your suggestion @kz3
        That's what I did too, but the widgets don't work if I set it up that way:
        The problem is that users who are not authorized on the MySQL server cannot see data in the widget even if they select other servers.
        Users who are authorized on the MySQL server can see their data as well as that of other hosts.
        • kz3
          • Jul 2025
          • 20
          Hey sorry to hear that . The idea i think it should work i think the problem maybe is on the permissions of the group
          by example in an imaginary group called (acces to vms) on the group permissions the host group containing the vms it should appear and allowed on read
          Because iwhen i tried a couple months ago i didn´t had any problem whit mysql just on permissions and user roles ... etc
          at this moment my zabbix server on maintenance but tomorrow maibe i can try it by myself and come back whit the results.
          • danielitm
            • Mar 2025
            • 28
            Yes, it is a permissions problem, but I would say it's one with the widget, because it doesn't pass the request on cleanly. It only checks if you have permissions for "MSSQL Server" in the example, and not for the server you selected via the host selection.
            • kz3
              • Jul 2025
              • 20
              it is possible i just tried
              this is from the guest user
              and this is from my user
              • kz3
                • Jul 2025
                • 20
                Two diferent host groups
                • kz3
                  • Jul 2025
                  • 20
                  So when the users groups were created y just give acces to the guests users to a group of hosts
                  while me or other user in their user group just has access to the data from other host group
                  • danielitm
                    • Mar 2025
                    • 28
                    If I understand correctly, you're working with fixed hosts there, not with the host navigator.
                    • kz3
                      • Jul 2025
                      • 20
                      I just translated it to english
                      in this case i can add two diferents data sets
                      But to put both on a single one you can too
                      ​Each host is is one host group , each user are on a diferent user group and on their user group each one only just have acces to one of the hosts groups so if user1 comes to see the dashboard is only gonna see one host data and the same for user2 ---- Thas the resume of all the post so people understand too
                      • danielitm
                        • Mar 2025
                        • 28
                        Then I could also build a dashboard for each group, but that would be dozens and I wanted to avoid that.
