JMX monitoring
  • Jayshankar
    • Apr 2017
    • 31
    JMX monitoring
    I am configuring the Java gateway
    ./configure --enable-java --prefix=/usr/local. Then run make command
    It doesn't create class file for all the java files. Why is the class files not getting created??. What are the steps required to configure java gateway.
    Thanks,
    Jayshankar
  • Atsushi
    • Aug 2013
    • 2028
    Please check the log messages.
    Has an error message been output?
    I think that you can judge what correspondence is necessary by that message.
    For example, you can not build Java development environment if it is not installed.
    • Jayshankar
      • Apr 2017
      • 31
      java JMX monitoring
      C[root@localhost sbin]# which java
      /home/jayshankar/jdk1.8.0_131/bin/java
      [root@localhost sbin]# which jar
      /home/jayshankar/jdk1.8.0_131/bin/jar
      which javac
      /home/jayshankar/jdk1.8.0_131/bin/javac
      Java jdk home is setup properly.Any other package needs to be installled
      • Atsushi
        • Aug 2013
        • 2028
        I can not tell by just that information.
        Please check the log at make execution.
        If JDK is installed, it is the following procedure to build.
        $ ./configure --enable-java --prefix=/usr/local
        $ make
        This builds the following file: (case Zabbix 3.0.9)
        src/zabbix_java/bin/zabbix-java-gateway-3.0.9.jar
        • Jayshankar
          • Apr 2017
          • 31
          java JMX monitoring
          JAVA Gateway is running successfully.
          java -server -classpath lib:lib/android-json-4.3_r3.1.jar:lib/logback-classic-0.9.27.jar:lib/logback-core-0.9.27.jar:lib/slf4j-api-1.6.1.jar:bin/zabbix-java-gateway-3.2.5.jar -Dzabbix.pidFile=/tmp/zabbix_java.pid com.zabbix.gateway.JavaGateway.
          What is the next step to start monitoring??.
          • ovas
            • Apr 2017
            • 138
            Configuring server for use with Java gateway, enabling remote JMX monitoring for Java application, configuring JMX interfaces and items in Zabbix GUI, these steps are described in the documentation:
            • Jayshankar
              • Apr 2017
              • 31
              java JMX monitoring
              I didn't get the second and third part enabling remote interface for JAVA monitoring. Where can i download Notepad.jar file for jdk8.
              • Atsushi
                • Aug 2013
                • 2028
                Notepad.jar is not necessary.
                You just start the application you use.
                As a option to start Java applications you want to monitor, add a setting to allow access by JMX.
                • Jayshankar
                  • Apr 2017
                  • 31
                  JMX monitoring
                  I am unable to understand the jmx setup. You can show me a sample configuration. I tried the below script at my end.
                  java \
                  > -Dcom.sun.management.jmxremote \
                  > -Dcom.sun.management.jmxremote.port=12345 \
                  > -Dcom.sun.management.jmxremote.authenticate=false \
                  > -Dcom.sun.management.jmxremote.ssl=false \
                  > -jar ./src/zabbix_java/bin/zabbix-java-gateway-3.2.5.jar
                  no main manifest attribute, in ./src/zabbix_java/bin/zabbix-java-gateway-3.2.5.jar
                  • Atsushi
                    • Aug 2013
                    • 2028
                    Do you want to monitor JavaGateway?
                    Is not it a Java application like Tomcat that you want to monitor?
                    ex. Tomcat 9
                    • Jayshankar
                      • Apr 2017
                      • 31
                      JMX monitoring
                      I am still unable to do JMX monitoring. Java 8 is installed on my system. I need help on tomcat setup.
                      Thanks,
                      Jayshankar
                      • allexpetrov
                        • May 2017
                        • 361
                        Thanks,
                        Jayshankar
                        Hi, Jayshankar!
                        To make it clear:
                        Which OSes you are using, where you've installed your Java Gateway(on the Tomcat server or on the Zabbix server) and how did you've installed your Tomcat (apt/yum or self-made from sources) ?
                        Regards,
                        Alex
                        • Jayshankar
                          • Apr 2017
                          • 31
                          JMX monitoring
                          My os is Fedora 25.
                          Java gateway is installed on the zabbix server machine. Logs of java gateway are as below:
                          2017-08-16 01:11:41.689 [main] INFO com.zabbix.gateway.JavaGateway - Zabbix Java Gateway 3.2.5 (revision 67445) has started
                          2017-08-16 01:11:41.769 [main] INFO com.zabbix.gateway.JavaGateway - listening on 0.0.0.0/0.0.0.0:10052.
                          Tomcat is not installed yet.
                          Thanks,
                          Jayshankar
                          • allexpetrov
                            • May 2017
                            • 361
                            So am I right that you want to monitor the Tomcat which isn't installed so far ? Then, I'm afraid we couldn't help you until you've installed the Tomcat.
                            Please install it on the system which you want to monitor, perform some config fix, suggested in his thread, and try to setup the host in Zabbix Frontend.
                            Regards,
                            Alex
                            • Jayshankar
                              • Apr 2017
                              • 31
                              #15
                              JMX monitoring
                              I have installed tomcat on linux machine. The port 8080 is currently working. What is the next step i have to do to get java gateway working.
                              Thanks,
                              Jayshankar
