Templates hub
  • SBO
    • Sep 2015
    • 226
    Templates hub
    Hi there,
    For different reasons, I need to run several different Zabbix at the office.
    I'd like to create a system that would manage the templates on all the zabbix, to be sure that we have the same names, versions, etc.. on all of them, and being able to update/add any new template on all the zabbix servers easily.
    Does someone here have the same issue ? How do you handle it ?
    My initial idea is to create another Zabbix Server, where I'll handle only the templates, nothing else, and then export the templates when I need with the API. But there's probably something way better than this !
