Odd behavior in monitoring
  • geostant
    • Feb 2015
    • 32
    Zabbix : 3.2.5
    Platform : Docker
    DB : MariaDB
    UI : Zabbix UI with NGINX
    I'm running zabbix based on docker for a while now
    and noticed 2 odd behaviors.
    1. When I've alerts on the hosts (e.g. "too many processes on host") and the hosts goes down the not only that the alerts doesn't stop, I don't get alert on agent isn't available
    2. I've another host that didn't had any issues and went down, again - no alert on agent isn't reachable
    I'm using the default OS LINUX template which I didn't changed + several other templates that I've created.
    I've made sure that the triggers are not disabled - especially the agent connectivity.
    Any one else encountered that issue ?
