Mathematical operators in JSONpath preprocessing
  • troffasky
    • Jul 2008
    • 640
    I have three items that work as JSONpath preprocess:
    $.tcp_statistics.connections_opened
    $.udp_statistics.connections_opened
    $.icmp_statistics.connections_opened
    https://www.zabbix.com/documentation..._functionality says we have some numerical operators.
    So I tried this:
    $.icmp_statistics.connections_opened + $.tcp_statistics.connections_opened + $.udp_statistics.connections_opened
    but:
    1. Failed: cannot extract value from json by path "$.icmp_statistics.connections_opened + $.tcp_statistics.connections_opened + $.udp_statistics.connections_opened": unsupported construct in jsonpath starting with: " + $.tcp_statistics.connections_opened + $.udp_statistics.connections_opened"
    It's not clear from the examples if what I am trying to do is supported. The only example with a mathematical operator in returns a string!
  • Markku
    • Sep 2018
    • 1784
    I think they can only be used in filter expressions.
    If you have three items and you want sum of those, you can create a calculated item and sum them there.
    Markku
    • troffasky
      • Jul 2008
      • 640
      Yet another Zabbix feature that is about 90% of the way to being useful for me I was trying to avoid having 4 items.
      • Markku
        • Sep 2018
        • 1784
        If those three pieces of data are from a single master item and you don't need them separately, you can use javascript preprocessing step to parse and sum them, to return and save just the single value.
        Markku
