3CX Services Monitoring
  • JonLock
    • Jul 2025
    I'm attempting to setup monitoring of 3CX services for our self-hosted instances. I have set up Zabbix and I have the 3CX services template but I am struggling to add our 3CX instances as hosts.
    All of our instances are Hyper-V VMs running the 3CX Linux build so I don't believe it's possible to install the Zabbix agent. How else can I achieve this?
    Any help would be greatly appreciated.
  • troffasky
    • Jul 2008
    • 639
    AFAICT all 3CX services are SystemD services. So I installed Zabbix Agent2 and applied template "Systemd by Zabbix agent 2". It seems to work fine, but have only done this on a couple of 3CX servers.
    It has discovered 12 services with 3CX in the name.
    • JonLock
      • Jul 2025
      Thanks for the reply. Sorry if I'm being simple but can you confirm you installed the Zabbix agent directly on the 3CX instance?
      • troffasky
        • Jul 2008
        • 639
        Yes.
        Some more words to make this post 10 characters.
