Performance Problem?
  • Hugo645
    • Jun 2017
    Hi Guys, i hope anybody have a idea..
    i start the server today at 2PM, we change it to a better hardware, because the old one was to slow for this. The data from 2PM to 2:30PM was ok.
    how can i adjust the max values per second?
    Number of hosts (enabled/disabled/templates) 4910 4868 / 0 / 42
    Number of items (enabled/disabled/not supported) 51098 26527 / 24328 / 243
    Number of triggers (enabled/disabled [problem/ok]) 26469 26467 / 2 [4139 / 22328]
    Required server performance, new values per second 401.45
    %Cpu(s): 23.2 us, 0.3 sy, 0.0 ni, 52.2 id, 24.2 wa, 0.0 hi, 0.1 si, 0.0 st
    KiB Mem : 65694252 total, 391512 free, 52206728 used, 13096012 buff/cache
    KiB Swap: 33409012 total, 33408816 free, 196 used. 12821872 avail Mem
    so a bit more than 50% idle time at the server, why they not processed more values per second? any idea?
  • LenR
    • Sep 2009
    • 1011
    A lot depends on what kind of items and any errors. What are the items? snmp, agent, agent active? How many pollers for the major item types?
    Check the logs for errors, especially timeouts.
