Widget, keys, templates
  • Datree
    • Aug 2025
    Hi All,
    New to Zabbix, I have imported templates and got Metrics flooding in. I am trying to make things easy to view at a glance but i am running into an issue i am unable to google to get an answer. I want to see CPU usage and Memory usage for all devices at glance. The issue is that in unifi template has the CPU utilization key name of unifi.cpu.util where Linux/windows severs have cpu.util (i think). my question is can i change the unifi template key name or is that required by the unifi device? can i map that value to match cpu.util that other systems use?
    thanks again.
    • 5002
    Key name is for Zabbix itself. It is not defined by the device, you are monitoring. You can change it as you wish... Key has to be unique within monitored host...
