Zabbix Monitoring support for Linux on POWER architecture.
  • ab123
    • May 2025
    Hi Team,
    We have few virtual machines running in the environment with Linux on Power architecture, CentOS 7, Circle Linux that needs to be monitored using Zabbix. Did not find any agent binaries support for these distributions here on the official website- https://www.zabbix.com/download. Would like to know if there is any workaround to monitor these or any roadmap for Zabbix to support this in future? Can it be done agentless from Zabbix side?
    Thanks for the help!
    • 5002
    Architecture Support
    • ARM64, x86_64, PPC64le (Actively supported)
    • POWER, IBM Z (Case-by-case)
    • PA-RISC, SPARC (Legacy, custom contract only)
    So I guess you need to ask...
    centos7 is anyway so old, that latest versions do not run on it... All of that power stuff seems outdated by now...
    • ab123
      ab123 commented
      Thanks for response!
