Zabbix and different levels of the same alert
  • StefanK
    • Jan 2023
    • 22
    I have two alerts for swap space remaining. One at 20% and one at 10%
    The issue I'm having is that once it reaches the 10% threshold both alerts are firing at the same time. How can i make it so that when the 10% threshold is reached the 20% threshold alert is resolved.
    I have tried the recovery expression but the issue is that the original expression never resolves so it does not work
  • LenR
    • Sep 2009
    • 1011
    Trigger dependency, the 10% depends on the 20%. (I think, sometimes I get them backwards)
    Edit: Yea, you're doing space remaining, so that's backwards. The less critical trigger depends on the more critical trigger, no matter what the numbers
    • StefanK
      • Jan 2023
      • 22
      https://www.zabbix.com/documentation...s/dependencies
      Yes. It is set up this way. The warning trigger is set at 20% space remaining and fires fine. When the critical trigger fires at 10% remaining the old one still stays open and sends mails
        • 5002
        You probably have expression like "swap<20%" and "swap<10%" ?? Of course both of them are true, if your swap space is something like 8%...
        change first one to "swap<20% and swap>10%" in that case it turns false, if your swap size is less than 10%...
