Discard broken item data
  • thooge
    • Mar 2014
    • 10
    i have some devices (thermometer) which are going sometimes to an
    undefined state.
    In this state i get a value of -999 which breaks my graphs badly.
    Is there a possibility to filter out such values at data acquisition?
    Kind Regards
    Thomas
  • batchenr
    • Sep 2016
    • 440
    what is the item key used ? can you post item conf ?
    • thooge
      • Mar 2014
      • 10
      Here is my item data.
      I think there is everything ok with zabbix.
      The sensor sometimes sends an invalid value e.g. -999 or -999.9.
      I want zabbix to ignore such values.
      Perhaps it is a feature request: define a range of valid
      values, e.g. -273 to infinite for temperatures in °C and
      let the system throw away invalid values.
      </item>
      <item>
          <name>Sensor 1 Value</name>
          <type>4</type>
          <snmp_community>public</snmp_community>
          <multiplier>1</multiplier>
          <snmp_oid>.1.3.6.1.4.1.21796.4.1.3.1.5.1</snmp_oid>
          <key>hwgSensor1Value</key>
          <delay>100</delay>
          <history>120</history>
          <trends>730</trends>
          <status>0</status>
          <value_type>0</value_type>
          <allowed_hosts/>
          <units>°C</units>
          <delta>0</delta>
          <snmpv3_contextname/>
          <snmpv3_securityname/>
          <snmpv3_securitylevel>0</snmpv3_securitylevel>
          <snmpv3_authprotocol>0</snmpv3_authprotocol>
          <snmpv3_authpassphrase/>
          <snmpv3_privprotocol>0</snmpv3_privprotocol>
          <snmpv3_privpassphrase/>
          <formula>0.1</formula>
          <delay_flex/>
          <params/>
          <ipmi_sensor/>
          <data_type>0</data_type>
          <authtype>0</authtype>
          <username/>
          <password/>
          <publickey/>
          <privatekey/>
          <port>161</port>
          <description/>
          <inventory_link>0</inventory_link>
          <applications>
              <application>
                  <name>Environment</name>
              </application>
          </applications>
          <valuemap/>
          <logtimefmt/>
      </item>
      • Semiadmin
        • Oct 2014
        • 1626
        Hi, thooge.
        Just correct the graph - set "Y axis MIN value" fixed and equal to your minimal temperature value.
        • thooge
          • Mar 2014
          • 10
          Your fix works for visualization.
          But i don't want that value in the database.
          E.g. it will be used for calculation on avg, trends etc. which
          leads to wrong values.
          • joseperes
            • Mar 2019
            • 20
            undefined state.
            Kind Regards
            Thomas
            I have the same situation, did you find a solution ?
            • Colttt
              • Mar 2009
              • 878
              If you use the latest version 4.2 yes its possible.
              Here you can read this: https://www.zabbix.com/documentation.../whatsnew420?s[]=validation#validation_and_throttling_rules
              Debian-User
              Sorry for my bad english
              • joseperes
                • Mar 2019
                • 20
                That's great news, unfortunately I Am in Zabbix 3.4 version and in my business they have no plans yet to upgrade the version. Is there another solution for this ?
                • Semiadmin
                  • Oct 2014
                  • 1626
                  In 3.4 you may use preprocessing with regexp.
                  To replace -999 with 0:
                  (-.*)|([\d.]*) 0\2
                  To discard -999 would be better to create a dependent item with preprocessing:
                  ([\d.]*) \1
                  In case of value -999 this dependent item becomes unsupported, but unlike master item unsupported dependent item doesn't require refresh interval for restoration.
                  • joseperes
                    • Mar 2019
                    • 20
                    (-.*)|([\d.]*) 0\2
                    ([\d.]*) \1
                    Hey thanks a lot! thats what I was looking for ! Using preprocessing with regex, how can I tell to discard values below -10C and above +40C ?
                    • Semiadmin
                      • Oct 2014
                      • 1626
                      Maybe, something like this one:
                      ^(-[\d]\..*)|^(-[\d])$|(^[1-3]\d\..*)|(^[1-3]\d)0$|(^[\d]\..*)|(^[\d])$|^(-10)$|^(40)$
                      \1\2\3\4\5\6\7\8
                      • joseperes
                        • Mar 2019
                        • 20
                        Hi there, I am using this regex to get only values in the range 0 to 9999
                        ^([0-9]|[1-8][0-9]|9[0-9]|[1-8][0-9]{2}|9[0-8][0-9]|99[0-9]|[1-8][0-9]{3}|9[0-8][0-9]{2}|99[0-8][0-9]|999[0-9]|1000)$                   \1
                        It's works fine but discards the value, I want to transform the value discarted in 0, how can I do that?
                        • Semiadmin
                          • Oct 2014
                          • 1626
                           ^([0-9]|[1-8][0-9]|9[0-9]|[1-8][0-9]{2}|9[0-8][0-9]|99[0-9]|[1-8][0-9]{3}|9[0-8][0-9]{2}|99[0-8][0-9]|999[0-9]|1000)$|.*                    0\1
                          • joseperes
                            joseperes commented
                            Thank you ! It worked
                        • joseperes
                          • Mar 2019
                          • 20
                          I have another situation that I need to get values in the range 0 to 100 and if the value goes above 100 should stay on 100. How can I do it ?
                          • Semiadmin
                            • Oct 2014
                            • 1626
                            #15
                            For example:
                            (^(\d){1,2}$)|.*                                    -\1-100
                            -(\d+)                                                \1
                            • joseperes
                              joseperes commented
                              This is only working for the range 0 to 99 ...
                            • joseperes
                              joseperes commented
                              I got working the range 0 to 100 with this regex: ^(100|[1-9]?[0-9])$ \1
                              Now I just need to transform on 100 when the number is over 100. How can I do it ?
