Escalation - question for repating
  • grefabu
    • Jul 2019
    • 45
    I've a question about the escalation of trigger actions:
    I want to define following for test:
    Alert every minute to one user/group
    Alert every fiveteen minutes to the boss
    I tried diffrent settings, one like that:
    But I got then for the boss a mail every minute too.
    I supposed if I set an extra duration this will override the default one?
    thank You
    Gregor
  • grefabu
    • Jul 2019
    • 45
    When I define two trigger actions, one with 1m and with the group as asignee and the other with 15m and the Boss it work like expected.
    But I'll like to use one trigger action, think that is should the prefered way,...
