Trigger dependency on a proxy
  • roaima
    • Aug 2025
    I've been reading the documentation about trigger dependencies at https://www.zabbix.com/documentation...s/dependencies
    I feel like I'm going round in dependency circles and I would value some external sanity checks!
    Running version 7.2.11. My configuration is such that I have an external Zabbix Server, and each of my (client) networks has its own internal Zabbix Proxy. The intention is that most of the Proxies will be running on a standalone Raspberry Pi. Each Proxy is (obviously) therefore behind its own Router. Furthermore, each Proxy communicates with the Server using encrypted messages.
    Each network's Router is polled with SNMP from its local Zabbix Proxy. I've done it this way rather than having the Zabbix Server itself poll each Router because SNMP v2 is unencrypted and I'd prefer traffic over the Internet to be encrypted.
    I'm trying to avoid a circular dependency between Proxy and Router, and I suspect I'm over thinking this. From the Zabbix Server's perspective everything hinges on being able to talk to the Proxy, but the Proxy can't communicate with the Server if the Router is down. Therefore for each network I think I have a series of trigger dependencies:
    • Router depends on the Proxy (so Zabbix Server will alert on the Proxy being unavailable)
    • Internal system #1 depends on the Proxy
    • Internal system #2 depends on the Proxy
    • etc.
    Questions, in no particular order:
    1. Is this the right approach, or should I just pull (unencrypted) SNMP data over the Internet from each Router to the Zabbix Server?
    2. Perhaps I should set up ICMP Ping from the Zabbix Server to each Router, and use that for a trigger dependency, leaving SNMP to be collected as before via the encrypted Proxy communication?
    3. How do I create a trigger dependency on a Proxy given that such devices aren't in the Host list for dependences?
    4. Should I instead be trying to create the trigger dependency against a Zabbix Agent running on the Proxy?
    Confused of North Yorkshire (UK)!
