HPE ILO by SNMP
  • KayserFranz
    • Mar 2023
    HPE ILO by SNMP
    Hi all,
    I'm running Zabbix 7.2.5 and I have some HPE Gen11 servers that I'm trying to monitor using the HPE ILO by SNMP template.
    But not all disks is found by Zabbix.
    Do you know what could be the issue here?
    But this is all I see in Zabbix.
  • ysus
    • Mar 2016
    • 104
    Can you see all drives from SNMPWALK?
    • KayserFranz
      • Mar 2023
      Hi ysus,
      This is all I get when I do a SNMPWALK.
      So I can see the disks, but no information about status of the disk, and no information about "expected lifetime" of the disk.
      • ysus
        • Mar 2016
        • 104
        Hi KayserFranz,
        "expected lifetime" might be internal calculation inside iLo and thus not visible via SNMP. Did you download private MIBs form HPE site which are specific for your server model? Since Zabbix relies on SNMPWALK you can't get more information than this utility returns.
        Just FYI - I have only one DL20 with SAS HDDs and media life metric is not available there. So it might be new feature of iLo 6 related to SSD which is not exposed via SNMP.
