Zabbix REST API auth parameter support in request body.
  • ab123
    • May 2025
    I am working on Zabbix REST API for some automation. The below request body works fine for API calls for Zabbix Server 7.0 with 'auth' parameter.
    "jsonrpc": "2.0",
    "method": "host.get",
    "params": {
    "output": ["hostid", "host", "name", "interfaces"],
    "filter": {
    "status": "0"
    "selectInterfaces": ["interfaceid", "ip"]
    "auth": auth_token,
    "id": 2
    However in Zabbix Server 7.4 REST API calls throws an error-: {"jsonrpc":"2.0","error":{"code":-32600,"message":"Invalid request.","data":"Invalid parameter "/": unexpected parameter "auth"."},"id":2}
    Is this parameter not supported in newer versions? or is it OS support issue as Zabbix Server version 7.0 is running on Ubuntu OS and 7.4 on RHEL 9
  • mariusl
    • Aug 2024
    • 34
    The auth property is indeed deprecated. You should use a bearer token in the Authorization header. If you need to retrieve one, use the user.login method. See https://www.zabbix.com/documentation.../en/manual/api for more details.
    • markfree
      • Apr 2019
      • 875
      You can create an API token through the web interface.
      The API documentation provides some examples.
      • Wikz47v
        • Sep 2025
        Thank you markfree
        • bitmester
          • Oct 2025
          Hi Wikz47v,
          what was the solution here, could you please share?
