Hi All
I'm new in zabbix and required to send notification if job process in my application is failed.
my understanding of the system brought me to try and create a new item which will listen to JMX mbean and then to create trigger on failed events which will be sent to an email.
this is my mbean
"MBean Name com.foresight.fsight.optimization.management:type= JMXNotificationManager,name=notificationManager"
from the documentation i understood i need 2 parameters to create an item
1. object name which i believe is equal to the mbean name
2. attribute name - which from my understanding after looking in jconsole is bmi.event
my questions are
1. is it possible to create item in the way i have described?
2. if so how should it looks like?
this is my mbean
my questions are
