Widget struggle. properties defined in action not retrieved.
  • Jeep
    • Aug 2025
    I'm playing around with the widget, i would like to create my own widget to get a sort of "top host/top item" customized item to display disk spaces....
    While i was playing i struggled a lot to defining prorperties in $data object.
    I struggled too much until i wanted to copy the template provided in the widget tutorial on the web-guide, and i found that on the new one it is working correctly.
    After this news i wanted to copy file-per-file on old project to check where is the problem, and...
    Surprise i got the same result, no changes on $data properties.
    Very Very strange!!!! Maybe a bug.
    Now i would like to know where is the problem on mine code so i'm here to ask to the most expertised.
    I've uploaded my code on git.
    Contribute to Jee-Dee/Zabbo_Plugin development by creating an account on GitHub.
    Below a screen of my page:
    Click image for larger version  Name:	immagine.png Views:	0 Size:	19.1 KB ID:	506818
    Click image for larger version  Name:	immagine.png Views:	0 Size:	48.3 KB ID:	506819
    I hope someone can help me to understand the arcane.
    Regards
