icmpping Trigger with .avg function not working?
  • johanpre44
    • Apr 2006
    • 40
    I've created a trigger, the expression on the template is {template:icmpping.avg(7200)}=0
    The icmpping item on this template is update every 15 minutes. The items are actually getting values
    The trigger should let me know if the ping was unsuccessfull for 8 pings (or in this case 7200 seconds which translates for 2 hours).
    This trigger does not seem to work. Is there myabe something wrong with my Logic, or does the zabbix server pinger freq have something to do with this.
    When I change the .avg(7200) to .last(0) the trigger does work.
    I also get lots of entries in my zabbix_server.log that looks like this:
    003269:20070115:130749 Evaluation of expression [{15908}=0] failed [Unable to get value for functionid [15908]]
    003269:20070115:130749 Expression [{15908}=0] cannot be evaluated [Unable to get value for functionid [15908]]
    When I create a trigger like this:
    {template:icmpping.last(0)}=0&{template:icmpping.p rev(0)}=0
    it does actually work (withouth the log file messages)
    Looks like Zabbix cannot do an Average of an integer value when the only possible values are 1 or 0. I changed the trigger to work an average on the pingsec float integer.
    Last edited by johanpre44; 16-01-2007, 08:50. Reason: Added additional information
