Modifying a Template
  • pitchfork
    • Aug 2025
    Greetings
    Looking through the templates that came "out of the box" - in this case "Windows By Zabbix". On our test system we are getting a high number of "Disk read/write request responses are too high" and I want to reduce the frequency.
    I can see in the macros where the expression:
    min(/WS2019-DEV/perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Read",60],15m) > {$VFS.DEV.READ.AWAIT.WARN:"0 C:"}
    is used and I can see how I can change the value of the macro $VFS.DEV.READ.AWAIT.WARN to override at the host level.
    What happens if I want to change the original template so that all hosts that are using this template get modified? I'm having difficulty finding out for example, how I would increase the "15m" in the expression above. I got as far as the expresion editor in the template but the fields do not appear to be editable.
    I'm sure I'm missing something very basic but having spent a few hours hunting the net for relevant info I thought I would appeal to the community.
    Nigel.
  • Answer selected by pitchfork at 12-09-2025, 03:07.
    cyber
    • 4970
    Open the template and edit it.. It will affect all hosts, where this template is attached. I have a feeling, you find the correct place from discovery and trigger prototypes...
      • 4970
      • pitchfork
        • Aug 2025
        Much appreciated - I was only two steps down the inheritance rabbit hole when I needed to be three.
        Cheers
        Nigel
