Existing passive proxy goes offline when adding new passive proxy
  • sagarkhushalani
    • Sep 2025
    We have 8 existing Zabbix proxies:
    * 6 active proxies (Let's say A1-A6)
    * 2 passive proxies, because of datacenter and firewall restrictions (P1 and P2)
    They work as expected. Performance is good, no issues as they are. Great.
    I need to add 2 more proxies (let's say P3 and P4), for 2 new regions. Due to firewall/datacenter restrictions, they must be passive.
    I have a firewall request pending, so I know they will be offline/unreachable until that is completed, but that's ok.
    Here's the issue:
    When I add P3 and P4 (offline/unreachable as expected), P1 and P2 also go offline. As soon as I take P3 and P4 out of the Zabbix configuration (deleting them from the UI), P1 and P2 come back online (it takes about a minute).
    They are entirely different machines, with different (fixed) IP addresses (different /24 subnets) and different A records, so I can't figure out why one set would affect the other.
    None of the active proxies are affected by this in any way.
    All passive proxy configuration files have the right "Server", "SourceIP" and "ListenIP" values set. When adding the proxies, I've tried using A records as well as IP addresses for the new proxie (P3 and P4) - no difference.
    Thoughts/ideas?
    # 0 = Active, 1 = Passive
    ProxyMode=1
    # Networking
    Server=zabbix-server-address
    Hostname=zabbix-proxy-p1
    HostnameItem=system.hostname
    ListenPort=10051
    SourceIP=<proxy-ip>
    ListenIP=<proxy-ip>
    # System
    LogType=console
    DebugLevel=3
    # Remote commands
    EnableRemoteCommands=1
    LogRemoteCommands=1
    # Process
    SocketDir=/var/run/zabbix
    # Database
    DBHost=127.0.0.1
    DBName=zabbix_proxy
    DBUser=zabbix
    DBPassword=<dbpassword>
    DBPort=13306
    # Frequencies
    HeartbeatFrequency=60
    ConfigFrequency=360
    DataSenderFrequency=30
    # Pollers
    StartPollers=100
    StartPollersUnreachable=25
    StartTrappers=25
    StartHTTPPollers=10
    # Cache
    CacheSize=2G
    HistoryCacheSize=1G
    HistoryIndexCacheSize=1G
    # External Utilities
    FpingLocation=/usr/sbin/fping
    Fping6Location=/usr/sbin/fping6
    I hope you just forgot to replace number here in example with something like pX.
    • sagarkhushalani
      • Sep 2025
      Oops, sorry yes! The proxy name in the config should have been pX for the example config. It is correct in the real configuration files for each proxy,
      • sagarkhushalani
        • Sep 2025
        Also, in the logs, even with debug level logging on, all I see is something like
        proxy <zabbix-proxy-p1> went offline.
        proxy <zabbix-proxy-p2> went offline.
        proxy <zabbix-proxy-p1> went online.
        proxy <zabbix-proxy-p2> went online.
