widget with count of hosts with running service
  • 1290er_Steve
    • Nov 2017
    Unfortunately, I haven't been able to find any information on this.
    Is it possible to display the number of hosts on which a specific service is running in a widget?
    For example: on how many hosts is the spooler service running?
    For the spooler service there is a item with the state of the service - running
    If so, are there instructions on how to do this?
    Best regards, Stephan
    I have a feeling, that you cannot get away without creating a calculated item for this...If you want to see a number. Otherwise you can sum item values on graph.
    • 1290er_Steve
      • Nov 2017
      Thanks for the tip. It helped me.
      For documentation purposes, and in case anyone else needs it, here's how I solved it:
      Calculated Item with the following formula:
      item_count(/*/service.info["Spooler",state]?[group="Windows Server"])
