7.4 - Help with widget
  • tme
    • Sep 2023
    Hi!
    I came across this blog post that shows a dashboard with sparkline charts.
    Here’s the screenshot:
    I’d like to recreate the top-right widget labeled “Container traffic”, but I can’t figure out how it was made.
    I'm using Zabbix 7.4 and I already have containers monitored, so I expected it to be straightforward, but I can’t seem to replicate it.
    Has anyone built something similar, or know the exact widget type/configuration behind it?
    Thanks in advance!
  • Answer selected by tme at 23-09-2025, 13:57.
    tme
    • Sep 2023
    I figured it out. Yes, it's most likely the top hosts widget.
    The problem was that I used the default Docker template, which creates items for each container. I followed this guide, which shows how to modify the discovery so that each container is created as a separate hosts.
      • 4970
      Top hosts widget probably, sorted by container name and item values represented as sparkline chart?
      • tme
        • Sep 2023
