Trigger on both max(,60s) and change() <> 0
  • db100
    • Feb 2023
    • 62
    i am trying to set a trigger that would fire if a metric changes and if its end value goes above a threshold for more than 60 seconds.
    so for example firing when a value goes from 0 to 1 and stays 1 for at least 60 seconds (this is because i want to avoid intermittency).
    The value comes in at a variable frequency but definitely more often than once per minutes, so the problem now is that changes() will only be true before 60 seconds have elapsed ....
    how to deal with this situation ?
  • Answer selected by db100 at 01-10-2025, 09:14.
    db100
    • Feb 2023
    • 62
    discussed in here: https://www.zabbix.com/forum/zabbix-...e-0#post507657
    this post need closure
    • db100
      • Feb 2023
      • 62
      btw i have tried in many ways to achieve this and while doing this i have encountered a lot of strange behaviors on functions like:
      * avg(change(<key>), 60s) --> always returns "60"
      * count(change(<key>), 60s) --> item cannot be created
      * max(changecount(<key>, 60s), 60s) --> always returns "60"
      and so on ...
      perhaps aggregate functions are not meant to be used in a nested way ?
      • AndrewAnderson
        • Sep 2025
        Wouldn't min(item,1m)>=1 be sufficient for this? a.k.a minimum value for an item was >=1 for last 60s?
          • 4957
          THats what I suggested in other same topic... (should be merged maybe)... And I think it shoudl be ok for "in at a variable frequency but definitely more often than once per minutes" situation, but there was later described a case, where gap was longer, so it does not fit this original setup any more..
          So maybe count of values for a minute has to be more than 2 and min value more than 1? that would rule out the case, when there is longer gap, and first incoming value after that is 1...
          • db100
            • Feb 2023
            • 62
