Proxies Zabbix Start Problems on Database Duplicate Key in Proxy_History_Pkey
  • Rodrigo_Patriota
    • Sep 2025
    Hi "Zabbixers",
    I am setting up a structure with 1 zabbix server and 2 zabbix proxies.
    I installed it with zabbix 7.4.2 and when I start the second proxy, I receive log messages in the database (postgresql 17) as follows:
    2025-09-25 10:41:10.541 -03 [26947] ERROR: duplicate key value violates unique constraint "proxy_history_pkey"
    2025-09-25 10:41:10.541 -03 [26947] DETAIL: Key (id)=(1516) already exists.
    2025-09-25 10:41:10.541 -03 [26947] STATEMENT: insert into proxy_history (id,itemid,clock,timestamp,source,severity,value,l ogeventid,ns,state,lastlogsize,mtime,flags,write_c lock) values (1516,69880,1758807640,0,'',0,'2684780544',0,21992 5837,0,0,0,0,1758807640),(1517,69940,1758807640,0, '',0,'3937341440',0,220206696,0,0,0,0,1758807640);
    I've already stopped both proxies and run the commands below:
    DO
    DECLARE
    seq RECORD;
    tbl TEXT;
    col TEXT;
    max_id BIGINT;
    BEGIN
    FOR seq IN
    SELECT
    c.oid::regclass::text AS seqname,
    n.nspname AS schemaname,
    t.relname AS tablename,
    a.attname AS colname
    FROM pg_class c
    JOIN pg_depend d ON d.objid = c.oid
    JOIN pg_class t ON d.refobjid = t.oid
    JOIN pg_attribute a ON a.attrelid = t.oid AND a.attnum = d.refobjsubid
    JOIN pg_namespace n ON n.oid = t.relnamespace
    WHERE c.relkind = 'S'
    AND d.classid = 'pg_class'::regclass
    AND d.refclassid = 'pg_class'::regclass
    AND n.nspname = 'public'
    LOOP
    tbl := seq.tablename;
    col := seq.colname;
    EXECUTE format('SELECT COALESCE(MAX(%I),0) FROM %I.%I', col, seq.schemaname, tbl)
    INTO max_id;
    RAISE NOTICE 'Resync sequence % -> next value %', seq.seqname, max_id+1;
    EXECUTE format('SELECT setval(%L, %s, false)', seq.seqname, max_id+1);
    END LOOP;
    END
    NOTICE: Resync sequence changelog_changelogid_seq -> next value 109199
    Even so, when I start the proxies again, I get the duplicate key messages again!
    What's going on, and how can I fix it?​​
