Hi guys
I'm in the process of moving from Nagios to Zabbix and would like some advice on the best way of handling the following checks:-
SSL cert expiry
Domain whois
Website Uptime
My initial idea is to create a Host for each website and also a template which does the checks above and makes use of the {HOST.NAME} variable.
This does appear to work, but is there a better way of doing this?
SSL cert expiry
Domain whois
Website Uptime
