Creating monitoring for a specific log to generate an alert
  • Marcelo Alves
    • Oct 2025
    I'm trying to create monitoring for generating alerts from a specific log located in a specific partition on a Windows server. I created the item and the trigger, but the alert is not being triggered. Can you help me figure out what I'm doing wrong? Below is the configuration I set up:
    Zabbix version 7.2
    Zabbix agent.cfg was configured as follows:
    Server=ZABBIX_SERVER_IP
    ServerActive=ZABBIX_SERVER_IP
    Hostname=HOST_NAME_IN_ZABBIX
    Item Created:
    Name: Error monitoring in log
    Type: Zabbix Agent (active)
    Key: logrt["D:\\Folder\\Folder\\Folder\\Folder\\Folder\\l og_a pp_*.txt","0",UTF-8,100,skip]
    The * after app_ is meant to identify the log for the day.
    Type of information: log
    Trigger Created:
    Severity: Warning
    Expression: logeventid(/SERVER/logrt["D:\\Folder\\Folder\\Folder\\Folder\\Folder\\l og_a pp_*.txt","0",UTF-8,100,skip])=1
    The "0" in quotes is meant to identify the line containing the error in the log.
    I tried using the expression below, but it shows an error in the expression
    {HostName:log["C:\\Logs\\particaoD\\meuarquivo.log","ERRO|FA IL", UTF-8,100,skip].strlen()} > 0
    • 5002
    Lets get back to regex basics... what means "*" ...
    a* - Matches zero or more consecutive `a` characters.
    so ... "log_app_*.txt" means... there is "zero or more _ characters" ...
    Next thing... are you looking for just a "0" in that file? Quite common thing, might get many false positives... Whatever line with a timestamp contains a 0 probably..
    And your trigger will not work... logeventid is meant for windows system log items... (as are logseverity and logsource functions)
    third thing.. that syntax for trigger where you try to use strlen is "old trigger syntax" changed already from v5, it will not work with 7.2...
    • Marcelo Alves
      • Oct 2025
      Hi, I found a regex that works for generating log alerts and it's working perfectly, thank you for your help.
