Zabbix agent key issues in repo
  • ccarls02
    • Sep 2025
    trying to install the zabbix agent2 on an ubuntu 24.04 server.. running zabbix server 7.0.19
    documentation seems a little lacking. i dont have any sort of GO environment, so building with source is out and the packages dont have an ubuntu option and seem to be 'agent 1' anyway
    how do i get there from here?
    • 4993
    no need to compile by yourself...
    https://www.zabbix.com/download?zabb...ubuntu&os_version=24.04&components=server_frontend_agent_2&db=pg sql&ws=nginx
    Exactly like it states there... Wget deb file, install it, run apt update and install agent2...
    Just tested on a 24.04 in WSL..
    me@laptop:~$ wget https://repo.zabbix.com/zabbix/7.0/ubuntu/pool/main/z/zabbix-release/zabbix-release_latest_7.0+ubuntu24.04_all.deb
    --2025-10-06 12:35:37--  https://repo.zabbix.com/zabbix/7.0/ubuntu/pool/main/z/zabbix-release/zabbix-release_latest_7.0+ubuntu24.04_all.deb
    Resolving repo.zabbix.com (repo.zabbix.com)... 2604:a880:2:d0::2062:d001, 178.128.6.101
    Connecting to repo.zabbix.com (repo.zabbix.com)|2604:a880:2:d0::2062:d001|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 8092 (7.9K) [application/octet-stream]
    Saving to: ‘zabbix-release_latest_7.0+ubuntu24.04_all.deb’
    zabbix-release_latest_7.0+ubu 100%[=================================================>]   7.90K  --.-KB/s    in 0s
    2025-10-06 12:35:38 (193 MB/s) - ‘zabbix-release_latest_7.0+ubuntu24.04_all.deb’ saved [8092/8092]
    me@laptop:~$ sudo dpkg -i zabbix-release_latest_7.0+ubuntu24.04_all.deb
    Selecting previously unselected package zabbix-release.
    (Reading database ... 41086 files and directories currently installed.)
    Preparing to unpack zabbix-release_latest_7.0+ubuntu24.04_all.deb ...
    Unpacking zabbix-release (1:7.0-2+ubuntu24.04) ...
    Setting up zabbix-release (1:7.0-2+ubuntu24.04) ...
    me@laptop:~$ sudo apt update
    Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
    Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
    Get:4 https://repo.zabbix.com/zabbix-tools/debian-ubuntu noble InRelease [2476 B]
    Hit:5 http://archive.ubuntu.com/ubuntu noble-backports InRelease
    Get:6 https://repo.zabbix.com/zabbix/7.0/ubuntu noble InRelease [3972 B]
    Get:7 https://repo.zabbix.com/zabbix-tools/debian-ubuntu noble/main Sources [1367 B]
    Get:8 https://repo.zabbix.com/zabbix-tools/debian-ubuntu noble/main all Packages [866 B]
    Get:9 https://repo.zabbix.com/zabbix/7.0/ubuntu noble/main Sources [32.1 kB]
    Get:10 https://repo.zabbix.com/zabbix/7.0/ubuntu noble/main amd64 Packages [65.0 kB]
    Get:11 https://repo.zabbix.com/zabbix/7.0/ubuntu noble/main all Packages [12.2 kB]
    Fetched 118 kB in 9s (13.6 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    All packages are up to date.
    me@laptop:~$ sudo apt install zabbix-agent2
    The following NEW packages will be installed:
      zabbix-agent2
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 5680 kB of archives.
    After this operation, 19.3 MB of additional disk space will be used.
    Get:1 https://repo.zabbix.com/zabbix/7.0/ubuntu noble/main amd64 zabbix-agent2 amd64 1:7.0.19-1+ubuntu24.04 [5680 kB]
    Fetched 5680 kB in 44s (129 kB/s)
    Selecting previously unselected package zabbix-agent2.
    (Reading database ... 41095 files and directories currently installed.)
    Preparing to unpack .../zabbix-agent2_1%3a7.0.19-1+ubuntu24.04_amd64.deb ...
    Unpacking zabbix-agent2 (1:7.0.19-1+ubuntu24.04) ...
    Setting up zabbix-agent2 (1:7.0.19-1+ubuntu24.04) ...
    Created symlink /etc/systemd/system/multi-user.target.wants/zabbix-agent2.service → /usr/lib/systemd/system/zabbix-agent2.service.
    invoke-rc.d: could not determine current runlevel
    Processing triggers for man-db (2.12.0-4build2) ...
    me@laptop:~$
    • ccarls02
      • Sep 2025
      ok thank you!
