Use same Item (system.uptime) in different Templates
  • M.Mommsen
    • Jun 2017
    Zabbix 3.2 with Web Frontend
    I need to create triggers in different templates, both depending on the hosts uptime!
    When I try to create a trigger using system.uptime, I have the problem that another template is using this key already - so I am not allowed to create the same item in the new template, because I get this error when connecting the templates to the hosts (and I need to keep the triggers in different templates):
    Item "system.uptime" already exists on "myhost", inherited from another template.
    So I tried to access the uptime from the other template, but that seems to be forbidden as well:
    Trigger "triggername" belongs to templates with different linkages.
