ODBC Poller logic, how many for monitoring around 20 DB with Template Oracle by ODBC
  • jurgen16
    • Jul 2023
    • 14
    How much ODBC pollers should have for monitoring around 20 DB's because I am reaching this trigger: Utilization of ODBC poller processes over 75%, when 2 of them goes down. In that case the trigger is raised and I am receiving from all DB's the trigger "Failed to fetch info data for last 5 minutes"
    I am using 6 ODBC Pollers for 14 DB, All time utilization is around those values: min: 0.2 % avg: 2.8% max:36.8% and in cases when one or two db's goes down is the real issue the utilization goes to 100%
    Zabbix Version: 6.0
    So how much is suggested for 20 DB monitored by ODBC?
    The template that I am using "Template DB Oracle by ODBC"
    #StartODBCPollers
    • 5002
    I do not know exact answer (too many variables in play), but I would just add some and check if the issue goes away.. I probably would go for 10 at first, observe situation and increase if needed.
    • jurgen16
      • Jul 2023
      • 14
      Thank you I will try this and let you know.
