Zabbix Agent 2 MySQL Plugin README?
  • rgingras
    • May 2025
    I'm trying to develop an item to track whether a MySQL server is Read-Only. Since that is not included in the status variables, I was hoping to use mysql.custom.query. I tried to use it with just that available documentation, but was not successful. That page however links to the plugin README at https://git.zabbix.com/projects/AP/r...Frelease%2F7.4. When following that link, I am sent to a login page with no sign-up option. I also cannot find it in the public repos at https://git.zabbix.com/repos?visibility=public. Is there a way for me to sign up to get access or is the README accessible elsewhere?
  • rgingras
    • May 2025
    Quick follow up: I found the link on the "Continue with username and password" page which directed me to https://support.zabbix.com/secure/Dashboard.jspa to sign-up. I did manage to make an account and sign in there, but using the same login for git.zabbix.com I get "You do not have permission to access Bitbucket."
      I wonder if they are planning to separate mysql plugin from agent2, as they have done with some other plugins... that link looks exactly like the ones leading to MSSQL or MongoDB plugins...
      https://git.zabbix.com/projects/AP/repos/ mysql/ browse/README.md (yours)
      https://git.zabbix.com/projects/AP/repos/ mssql/ browse/README.md
      https://git.zabbix.com/projects/AP/repos/ mongodb/ browse/README.md
      • rgingras
        rgingras commented
        Thanks for the links, but those are the ones I can't access due to the login page. I just did another trawl through the public repos and I did find https://git.zabbix.com/projects/ZBX/...ysql/README.md which seems to be the README I was looking for. I think I can file an issue to get the documentation updated with the correct links now that I've found them.
      • rgingras
        rgingras commented
        Oh, I see what happened. They used the same link format for the mysql plugin, even though it hasn't been separated into a different repo. BitBucket must be throwing the login screen instead of just giving me a 404 which made me think it was inaccessible.
    • rgingras
      • May 2025
      Filed https://support.zabbix.com/browse/ZBX-27084 to get the documentation updated.
