I am new to Zabbix and have just implemented a brand new Zabbix 7.4 environment. I was wondering if anyone could provide some advice on the best way to monitor a 2 node active/active Windows Failover Cluster hosting multiple instances of SQL Server as individual cluster resources.
I intend to use Zabbix Agent2 as from what I read it seems to be the better and most up to date option to use. We have an old Zabbix v5 solution currently monitoring the SQL clusters however this is reliant on a lot of manual configuration within Zabbix (this was done by someone else and not documented) and also relies on PowerShell scripts used by the Zabbix agent which I would ideally not like to rely on unless necessary.
Any advice would be gratefully received, thanks!
