{Item.value1} and {item.value2} showing same value?
  • Linwood
    • Dec 2013
    • 398
    I have a trigger expression that looks like this (this is the actual host's expression, that originates on a template's trigger prototype):
    last(/OfficeSWXG/Speed[Port 9],#1)<>last(/OfficeSWXG/Speed[Port 9],#2)
    In the name of the trigger it looks like this:
    Port 9 Speed change on port {ITEM.VALUE2} to {ITEM.VALUE1}
    When it fires, it shows like this (a cut/paste direct from the problem display when it is showing (and should be showing) a problem):
    Port 9 Speed change on port 1 Gbps to 1 Gbps
    Always shows the same value. This despite the history showing a clear change (0 -> 1 then back). It's as though it is showing the same thing twice.
    The trigger is working, the values are right in the item history, everything is right but the title.... the title seems to be picking one of them twice instead of each separately. Is that because it's the same item (but a different last instance)? Bug? Am I doing something wrong syntactically?
  • troffasky
    • Jul 2008
    • 631
    "indexed macros" refer to items by their position in the trigger expression, not by their values in time. Value1 and Value2 are the same item, so you see the same value twice.
    I am not sure what the solution is. There probably is one.
    • BP_Vital
      • Feb 2016
      • 50
      Try {FUNCTION.VALUE1} and {FUNCTION.VALUE2}, those supposed to resolve to the values of the first and second item-based functions at the time of the event.
        • 4961
        Function macros or expression macros. In this case function ones seem more appropriate..
        • Linwood
          • Dec 2013
          • 398
          Function took care of it. I had not even noticed those existed, been a long time since I wrote new trigger expressions. Thank you BP_Vital and cyber you nailed it.
