Detection of ansible runs.
  • neorejdv76
    • Nov 2021
    • 15
    I would like to monitor ansible runs that are (or have been) executed on a (linux) host.
    Things i would like to know:
    - If there has been a ansible run in the last x hours.
    - With what user the run has been done.
    - Possible what playbook(s) has been used.
    I think it can be done with userparameters, and do some magic (grepping,sed,awk) in the /var/log directory?
    Or maybe there is a more clever way of doing this?
    I am using zabbix_agent2 as agents.
    We do not use any Redhat automation tooling or any other tools like that.
    Any allready has a similair solution for this?
    Are you auditing your users, writing down all their commands, they have used? If yes, you probably can find it from audit logs...
    But that is only for a host where that playbooks is executed... I dont think there is any notice o the target host(s), is it done by human or ansible.. Only if a specific user is used, so you can say, that "ansible user" has visited us...
