Web monitoring add bearer token auth header
  • raigo
    • Jul 2017
    I need to monitor REST API which requires authentication.
    I know that in web monitoring I can add headers. but how to change the header
    dynamically (add bearer token)?
    How to configure Zabbix web monitoring in two steps
    1)It asks for OAuth 2.0 token from token service (IdentityServer)
    2)Adds that token as Authorization header
  • valten
    • Mar 2020
    raigo
    I have exact same problem.I can't change my access token dynamically. Did you find any solution?
    • tim.mooney
      • Dec 2012
      • 1432
      valten , did you read the Web monitoring chapter of the Zabbix documentation, including the "real world example"? It gives some ideas how to use a regex to dynamically capture a token from one step in the process and then submit that token for later steps, either in the headers or as part of the POST data.
      • valten
        • Mar 2020
        Yes, thanks, I've been able to achieve my goal with autorization.
        Now I can't get response body from Web monitoring. Can't find any info on that on this forum.
