Hey,
i have a strange Problem when i add the MySQL by Zabbix agent 2 Templates to my Mariadb Replicas in a GTID Replication the GTID Jumps
deppending on the server so
Maria-DB-3 jumps to 1-3-*
Maria-DB4 jumps to 1-4-*
etc
In the Replication log i can see that the jumps happens when the Databases trys to Truncate a Tabbele wich it normaly does not do if i do not have the Template applied to the Server the GTID also does not jump.
Is there some sort of setting i can set in the Template that woud stop it from "jumping" the GTID?
Thanks for any Help.
etc
0xb50968cc GTID 1-1-34142305 trans thread_id=7638583 /*M!100001 SET @@session.gtid_seq_no=34142305*//*!*/; START TRANSACTION /*!*/; # at 718505 # at 718659 #251018 17:10:58 server id 1 end_log_pos 0 CRC32 0xe14bcc39 Annotate_rows: #Q> UPDATE IP2Files #Q> SET size='104628351' #Q> WHERE ip='/' AND usr_id='0' AND file_id='87883' #251018 17:10:58 server id 1 end_log_pos 0 CRC32 0xdca9da94 Table_map: xfs.IP2Files mapped to number 56 # at 718727 #251018 17:10:58 server id 1 end_log_pos 0 CRC32 0xa37bf9fc Update_rows: table id 56 flags: STMT_END_F ### UPDATE xfs.IP2Files ### WHERE ### @1=87883 /* INT meta=0 nullable=0 is_null=0 */ ### @2='/' /* VARSTRING(45) meta=45 nullable=0 is_null=0 */ ### @3=0 /* MEDIUMINT meta=0 nullable=0 is_null=0 */ ### @4=0 /* MEDIUMINT meta=0 nullable=0 is_null=0 */ ### @5=102136891 /* LONGINT meta=0 nullable=0 is_null=0 */ ### @6=0.0000 /* DECIMAL(8,4) meta=2052 nullable=0 is_null=0 */ ### @7='/kut1cxceu62i' /* VARSTRING(255) meta=255 nullable=0 is_null=0 */ ### @8=1760799814 /* TIMESTAMP(0) meta=0 nullable=0 is_null=0 */ ### @9=0 /* TINYINT meta=0 nullable=0 is_null=0 */ ### @10='Not completed' /* BLOB/TEXT meta=2 nullable=1 is_null=0 */ ### SET ### @1=87883 /* INT meta=0 nullable=0 is_null=0 */ ### @2='/' /* VARSTRING(45) meta=45 nullable=0 is_null=0 */ ### @3=0 /* MEDIUMINT meta=0 nullable=0 is_null=0 */ ### @4=0 /* MEDIUMINT meta=0 nullable=0 is_null=0 */ ### @5=104628351 /* LONGINT meta=0 nullable=0 is_null=0 */ ### @6=0.0000 /* DECIMAL(8,4) meta=2052 nullable=0 is_null=0 */ ### @7='/kut1cxceu62i' /* VARSTRING(255) meta=255 nullable=0 is_null=0 */ ### @8=1760799814 /* TIMESTAMP(0) meta=0 nullable=0 is_null=0 */ ### @9=0 /* TINYINT meta=0 nullable=0 is_null=0 */ ### @10='Not completed' /* BLOB/TEXT meta=2 nullable=1 is_null=0 */ # Number of rows: 1 # at 718909 #251018 17:10:58 server id 1 end_log_pos 718940 CRC32 0x540f60ca Xid = 58926 COMMIT/*!*/; # at 718940 #251018 17:10:59 server id 2 end_log_pos 718982 CRC32 0x1a4201ca GTID 1-2-34142306 thread_id=4 /*M!100001 SET @@session.server_id=2*//*!*/; /*M!100001 SET @@session.gtid_seq_no=34142306*//*!*/; # at 718982 #251018 17:10:59 server id 2 end_log_pos 719076 CRC32 0x29ee4195 Query thread_id=4 exec_time=0 error_code=0 xid=0 SET TIMESTAMP=1760800259/*!*/; SET @@session.sql_mode=1411383296/*!*/; /*!\C utf8mb4 *//*!*/; SET @@session.character_set_client=utf8mb4,@@session.collation_connection=2304,@@session.collation_server=2304/*!*/; TRUNCATE TABLE xfs.Progress /*!*/; DELIMITER ; # End of log file ROLLBACK /* added by mysqlbinlog */; /*!50003 SET COMPLETION_TYPE=@OLD_COMPLETION_TYPE*/; /*!50530 SET @@SESSION.PSEUDO_SLAVE_MODE=0*/; root@Maria-DB-2:/mnt/sqldata#
