installing zabbix
  • dvir
    • Jul 2017
    installing zabbix
    Hi ,
    i want to install zabbix , every time i hit another obstacle.
    anyone can help or give a link to a working procedure how to install zabbix on Ubuntu , preferably detailed because im new to Linux.
    thank you
  • batchenr
    • Sep 2016
    • 440
    Originally posted by dvir
    Hi ,
    thank you
    post some of the errors that you get.
    i have how to install on centos
    do you want to install from source or rpm ?
    • sartecat
      • Jul 2017
      • 13
      Hi ,
      thank you
      I'm not sure what system or version you want. The link is for zabbix 3.2 on ubuntu 16,04 LTS: http://yallalabs.com/linux/how-to-in...ntu-16-04-lts/
      If you get errors, post your problem in detail.
      • dvir
        • Jul 2017
        thank you
        i will give it a try
        • dvir
          • Jul 2017
          Thank you , i manage to install zabbix according to this manual...
          but
          1. i choose to install LAMP during ubuntu installation.
          2. all the php7.0-xxx modules changed to php-xxx so it probably installed latest version.
          thank you very much
