Hello to all,
I have problem getting correct SNMP values from Huawei Entity MIB. I want to make Huawei Entity discovery template with informations about CPU, memory, voltage... And that discovery would use entPhysicalDescr OID:
iso.3.6.1.2.1.47.1.1.1.1.2.16777216 = STRING: "Assembling Components,NetEngine40E,CR5B0BKP0871,NE40E-X8A Integrated Chassis DC Components (Including 2 Fan Tray)"
iso.3.6.1.2.1.47.1.1.1.1.2.16842752 = STRING: "LPU slot 1"
iso.3.6.1.2.1.47.1.1.1.1.2.16842753 = STRING: "12-Port 10GBase LAN/WAN-SFP+ Integrated Line Processing Unit(LPUI-120)"
iso.3.6.1.2.1.47.1.1.1.1.2.16843008 = STRING: "Card slot 1/0"
iso.3.6.1.2.1.47.1.1.1.1.2.16843264 = STRING: "Card slot 1/1"
iso.3.6.1.2.1.47.1.1.1.1.2.16847104 = STRING: "12-port 10GBase LAN/WAN-SFP+ Fixed Card"
iso.3.6.1.2.1.47.1.1.1.1.2.16847105 = STRING: "10300Mb/s-1310nm-LC-10km(0.009mm)"
iso.3.6.1.2.1.47.1.1.1.1.2.16847106 = STRING: "GigabitEthernet1/0/1"
iso.3.6.1.2.1.47.1.1.1.1.2.16847116 = STRING: "10300Mb/s-1310nm-LC-10km(0.009mm)"
iso.3.6.1.2.1.47.1.1.1.1.2.16908288 = STRING: "LPU slot 2"
iso.3.6.1.2.1.47.1.1.1.1.2.16908289 = STRING: "48-Port 100/1000Base-X-SFP Integrated Line Processing Unit E(LPUI-51-E)"
iso.3.6.1.2.1.47.1.1.1.1.2.16908544 = STRING: "Card slot 2/0"
iso.3.6.1.2.1.47.1.1.1.1.2.16908800 = STRING: "Card slot 2/1"
iso.3.6.1.2.1.47.1.1.1.1.2.16912640 = STRING: "24-Port 100/1000Base-X-SFP Fixed Card"
iso.3.6.1.2.1.47.1.1.1.1.2.17367040 = STRING: "MPU slot 9"
iso.3.6.1.2.1.47.1.1.1.1.2.17367041 = STRING: "Finished Board Unit,NetEngine40E,CR57SRUA480A81,Switch and Route Processing Unit A8(16G Memory)"
iso.3.6.1.2.1.47.1.1.1.1.2.17367296 = STRING: "CFCARD slot 9/0"
iso.3.6.1.2.1.47.1.1.1.1.2.17371392 = STRING: "CFCARD 9/0"
iso.3.6.1.2.1.47.1.1.1.1.2.17375489 = STRING: "GigabitEthernet9/0/0"
iso.3.6.1.2.1.47.1.1.1.1.2.17432576 = STRING: "MPU slot 10"
iso.3.6.1.2.1.47.1.1.1.1.2.17432577 = STRING: "Finished Board Unit,NetEngine40E,CR57SRUA480A81,Switch and Route Processing Unit A8(16G Memory)"
iso.3.6.1.2.1.47.1.1.1.1.2.17432832 = STRING: "CFCARD slot 10/0"
iso.3.6.1.2.1.47.1.1.1.1.2.17436928 = STRING: "CFCARD 10/0"
iso.3.6.1.2.1.47.1.1.1.1.2.17441025 = STRING: "GigabitEthernet10/0/0"
iso.3.6.1.2.1.47.1.1.1.1.2.17498112 = STRING: "SFU slot 11"
iso.3.6.1.2.1.47.1.1.1.1.2.17498113 = STRING: "480Gbps Switch Fabric Unit C(SFUI-480-C)"
So I need CPU,MEM,TEMP and all other informations for Entities such "MPU slot 9", "LPU slot 1", "SFU slot 12" etc...
Problem is that with CPU/MEM/TEMP OIDs for those entities and their INDEXES I don't get correct values, it is always 0. Correct values are under snmp indexes which are 1 above.
Example for CPU usage:
snmpwalk -v2c -c xxx xxxx 1.3.6.1.2.1.47.1.1.1.1.2.17367040
snmpwalk -v2c -c xxx xxx 1.3.6.1.4.1.2011.5.25.31.1.1.1.1.5.17367040
iso.3.6.1.4.1.2011.5.25.31.1.1.1.1.5.17367040 = INTEGER: 0
Correct information about CPU usage for "MPU slot 9" is under SNMP index 17367041
snmpwalk -v2c -c xxx xxx 1.3.6.1.4.1.2011.5.25.31.1.1.1.1.5.17367041
iso.3.6.1.4.1.2011.5.25.31.1.1.1.1.5.17367041 = INTEGER: 33
How can I tell zabbix that for "MPU slot 9" doesn't look for its original index (17367040) but to look for 1 higher (17367041)?
