Zabbix Migration - Problems - Appliance Alarm Monitoring
  • earth-spark
    • Jun 2025
    I'm seeking advice on whether this is feasible with Zabbix and, if so, the best implementation method.
    Requirement
    To monitor alarms on a specific group of appliances by replicating them within Zabbix. This would provide the team with visibility into the estate and maintain a history of how often alerts are triggered/re-triggered.
    We mustn't miss alarming data, so for the first stage, I would focus on polling the device via the API vs SNMP Traps.
    Appliance Alarms
    The appliance features an API for viewing active alarms and offers the option to send these alarms via SNMP Traps.
    We need to replicate these alerts on the deployed appliances within Zabbix, providing the team with visibility of the estate and maintaining a history of how often the alerts are triggered/re-triggered.
    • There are 436 different types of alarms, determined by an alarmID such as "system/alertX" and "license/recording/alertY",
    • The alarm can trigger on multiple objects within the device. To determine if an alarm is unique, we can combine the host, alarm ID, config ID, and alarm details.
    • The alarm also contains the following details: severity, slot, alarm description, time raised, and position.
    • Once the alarm clears, it is no longer in the returned data from the API.
    Current status
    • Created an external script that puts the active alarms into a Master Item every minute. If the script fails, it returns an empty object.
    • Created a Master Item that included all the components discovered on the device, updated every hour.
      • Using the Discovery prototype Item to generate all the elements as items with no data
    However, going down this route, I assume I would need 436's trigger items per component, and then to trigger on the data from the Master Alarm item, on the item in question.
    A device can have 200+ components and 80k+ triggers, which certainly does not scale.
