How to have different triggers on same SNMP discovery?
  • compuj85
    • Sep 2025
    I'm using the template Supermicro Aten by SNMP to monitor many Supermicro servers in Zabbix 7.4.3.
    This template does an SNMP discovery of all temperature sensors with this OID:
    discovery[{#SNMPVALUE},1.3.6.1.4.1.21317.1.3.1.2,{#SENSOR_DE SCR},1.3.6.1.4.1.21317.1.3.1.13]
    This discovers CPU temperatures, NIC temperatures, and GPU temperatures. The problem is that all of these use the same {$TEMP_WARN} and {$TEMP_CRIT} macro; and the GPUs can run much hotter than the CPU or NIC - around 80*C in some cases. To avoid alarms I've had to set {$TEMP_CRIT} very high, higher than I would like for the CPUs.
    Is there a way to have a different limit based on the item name? In the Discovery Rule Override I think I can change the severity based on {#SENSOR_DESCR}, but not the trigger value. Items get names like CPU 1 Temp, GPU1 Temp, etc.
    Thanks,
    -Jason
  • PSklyar
    • Sep 2025
    • 30
    Hey hey !
    I can advise you to configure discovery rule overrides
    Create custom macros for each sensor type, like :
    {$TEMP.CPU.WARN} = 70
    {$TEMP.CPU.CRIT} = 80
    {$TEMP.GPU.WARN} = 85
    {$TEMP.GPU.CRIT} = 95
    https://blog.zabbix.com/extend-your-...errides/15496/
    Then create 3 overrides, cpu temp trigger / gpu temp trigger and nic
    • compuj85
      • Sep 2025
      That's where I'm confused - I see where the override can change the severity, add tags, prevent the trigger creation... but not use different macros.
      Thanks,
      -J
      • compuj85
        • Sep 2025
        I was able to solve this with regex in the macro (notes here: https://www.zabbix.com/documentation...cros_context):
        {$TEMP_CRIT} 75
        {$TEMP_CRIT:regex:".*10G.*"} 80
        {$TEMP_CRIT:regex:".*NIC.*"} 80
        {$TEMP_CRIT:regex:"GPU.*"} 90
        Thanks,
        -J
