Issues monitoring Kafka using JMX (Zabbix Java Gateway)
  • onallion
    • Mar 2016
    • 131
    Hey guys,
    I've been given a task to monitor Kafka via Zabbix:
    • I installed Zabbix Java Gateway as per the instructions, on the same server as the Zabbix Server.
    • Enabled JMX via port 12345 on one of my Kafka hosts by adding the following lines to its config:
      # JMX settings
      if [ -z "$KAFKA_JMX_OPTS" ]; then
      KAFKA_JMX_OPTS="-Dcom.sun.management.jmxremote -Dcom.sun.management.jmxremote.port=12345 -Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.ssl=false "
      fi
    • Restarted Kafka
    • Allowed port 12345 from Zabbix Server to a Kafka host in the FW
    • Checked Telnet from Zabbix Server to Kafka host - connection established
    • Added JMX interface to the host in Zabbix frontend
    • Linked template to host (template from here: https://github.com/helli0n/kafka-monitoring)
    Unfortunately, in the Zabbix Server log I am seeing errors like the following:
    JMX agent item "jmx["kafka.network:type=SocketServer,name=NetworkProcessorAvgIdlePercent","Value"]" on host "kafkahost" failed: another network error, wait for 15 seconds
    And then:
    temporarily disabling JMX agent checks on host "Sandbox-Kafka-hrc1": host unavailable
    I then check the frontend and the host has "JMX" in red with the error "ZBX_TCP_READ() timed out".
    I'm kind of at a loss as to why this is not working, and don't know how to continue checking further. Any help would be appreciated!
  • onallion
    • Mar 2016
    • 131
    In case anyone runs into this, I've solved it.
    The line in the configuration file should be:
      KAFKA_JMX_OPTS="-Dcom.sun.management.jmxremote=true -Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.ssl=false -Djava.net.preferIPv4Stack=true -Dcom.sun.management.jmxremote.rmi.port=8989"
    fi
    (Note for the port you can choose anything that is available, and you will need to allow in your FW).
    Then edit kafka-server-start.sh and add the following:
    export JMX_PORT=${JMX_PORT:-12345}
    (For this you can also use any available port, but 12345 is the default one Zabbix uses for JMX interface so I just used it).
    The problem was that unless you define "Dcom.sun.management.jmxremote.rmi.port=" it will use a random one.
    • kaloyan.s
      • Nov 2016
      • 13
      Thank you onallion.
      It is very useful.
      Cheers,
