Count Zabbix Items per host/hostgroup
  • jefersonantonio
    • Jul 2017
    How can i count the numbers of items per host/hostgroup? Is it possible?
    For example, i have this items below and i need the sum of this items
    Item example 1 - (23)
    Item example 2 - (5)
    sum=28
    You can find more info the image attached.
  • batchenr
    • Sep 2016
    • 440
    sum=28
    yes,
    go to zabbix GUI-> Configuration -> Hosts
    at the host screen you will see all ur host and there item
    choose one host and press on its items tab
    then you will get to 'item' screen
    there in the filter delete the host name
    and in Name chose the item you want to count name or key under
    key filter
    • jefersonantonio
      • Jul 2017
      Thanks batchenr!
      How can i do that by sql(mysql)? Do you know?
      • batchenr
        • Sep 2016
        • 440
        Thanks batchenr!
        Hey yes-
        what i did to get it is to run :
        watch "mysql -e \"SELECT COMMAND,TIME,STATE, INFO  FROM information_schema.processlist WHERE COMMAND='Query'\""
        and then run the search and see how zabbix run it in the DB.
        the quary should be : change '%ITEM.NAME%' to your item name.
        use zabbixdb;
        SELECT i.itemid,i.type,i.hostid,i.name,i.key_,i.delay,i.history,i.trends,i.status,i.value_type,i.error,i.templateid,i.flags,i.state FROM items i WHERE i.type<>9 AND i.flags IN (0,4) AND ( (  UPPER(i.name)  LIKE [B]'%ITEM.NAME%'[/B] ESCAPE '!' ) ) ORDER BY i.status LIMIT 1001 OFFSET 0;
        • janssenreis
          • May 2010
          • 64
          Better to use an API than to do SQL queries.
          • Rudlafik
            • Nov 2018
            • 168
            "jsonrpc": "2.0",
            "method": "host.get",
            "params": {
            "output": ["hostid"],
            "groupids": "No of Host Group",
            "countOutput": true
            "auth": "Your Auth Key",
            "id": 1
