I've missread your answer. you don't need zabbix agent on the appliance
But i don't know if you can do this with zabbix_get. Sorry
Edit 2 :
From the man page, you can't use zabbix_get without a zabbix-agent on the remote host :
zabbix_get is a command line utility for getting data from Zabbix agent.
And The documentation says :
Simple checks are normally used for remote agent-less checks of services.
Note that Zabbix agent is not needed for simple checks. Zabbix server/proxy is responsible for the processing of simple checks (making external connections, etc).
But Simple checks are not really complicated to test
icmpping : use ping command
net.tcp.service : use telnet command
net.udp.service : use netcat / nc command
