Triggers with multiple items, one of them disabled
  • fabio.grasso
    • Jul 2017
    I'm trying to do a configuration in Zabbix: I have a trigger with a lot of items concatenated using "or" or "and".
    If I disable an item all the trigger stop to work and go in status "Unknow" due to "Cannot evaluate function xyz: item is disabled"
    For my environment is very useful for me to have a trigger with a lot of items associated but I don't like that disable a single item will disable also the trigger.
    Is it possible to keep the trigger active even if an item is disabled?
