triggering a directory change
  • new2zabbix2
    • Nov 2025
    hi,
    I am new here.
    using zabbix ver 7.0.21.
    I am trying to get trigger is a directory on a windows server host (2019 with agent 7.0X) has not been changed for the last 5 min.
    (usually this directory is very active so if files stops coming I need to know)
    I created a trigger like this:
    change(/Server1/vfs.file.time["D:\LIB",modify])>5
    but the behavior is not as expected.
    can any one point me where am I wrong and what should be the correct syntax?
    • 4969
    I am not sure, does windows even has such value for a directory, as you need (as you have in linux)... The value, what you get is actually directory creation time, not modifying time (and probably does not change at all)...
    and expecting a "change()>5" to mean more than 5 minutes is also wrong... time is measured in seconds, not minutes...
    • new2zabbix2
      • Nov 2025
      hi,
      thanks for your response.
      there is defiantly creation date and modify date.
      • troffasky
        • Jul 2008
        • 634
        This works for me:
        now()-last(/servername/vfs.file.time[E:\foldername])>1209600
        and fires when foldername hasn't had a new file created in it for 2 weeks.
