Setting up MQTT monitoring with Zabbix 6.0(LTS), agent2, mosquitto and zigbee2mqtt
  • cgrenier
    • Nov 2025
    Hello
    On a Raspberry pi, zigbee2mqtt is sending the results to a local mosquitto instance and zabbix-agent 2 is running with active checks enabled.
    On the zabbix server interface, a master item has been created for the Raspberry pi:
    - name: zigbee-cgr
    - type: Zabbix agent (active)
    - key: mqtt.get["","zigbee2mqtt/zigbee-cgr/#"]
    - no preprocessing
    When I asked for previous values, I can results like
    2025-11-17 16:41:58 {"zigbee2mqtt/zigbee-cgr":"{"humidity":48.95,"linkquality":224,"t e mperature":22.17}"}
    A dependant item has been created:
    - name: Temperature [C]
    - type: Dependant Item
    - Key: temperature
    - Type of information float
    - Master item: zigbee-cgr
    - Preprocessing: JSONPath $.temperature
    Preprocessing failed for: {"zigbee2mqtt/zigbee-cgr":"{"humidity":49.39,"linkquality":232,"t e mperature":21.93}"}
    1. Failed: cannot extract value from json by path "$.temperature": no data matches the specified path
    I have found another post about MQTT but it wasn't using mosqutto. I also read Ivo_Schooneman_Feeding_Zabbix_with_MQTT_data.pdf without understanding what was broken in my setup.
    What should I do to fix it ?
  • Answer selected by cgrenier at 02-12-2025, 17:17.
    cgrenier
    • Nov 2025
    Thanks for your help. I have been able to solve it by adding a PreProcessing in the master item.
    On the zabbix server interface, a master item for the Raspberry pi is now
    - name: zigbee-cgr
    - JSONPath Preprocessing $['zigbee2mqtt/zigbee-cgr']
    The dependant item is unchanged:
    - Key: temperature
    • BP_Vital
      • Feb 2016
      • 50
      I'd say fixing template would be faster to include those extra spaces if they appear everywhere,
      OR additional custom preprocessing step to convert "t e mperature" -> "temperature" is a shortcut too.
      • cgrenier
        • Nov 2025
        Thanks for your reply but the extra spaces only appears in my post on the zabbix forum when I choose "Preview" in the forum (maybe to wrap long line).
        Another idea ?
        • BP_Vital
          • Feb 2016
          • 50
          I'm confused by slash symbols in the master item JSON. Maybe try to preprocess string getting rid of them?
          Also i suspect $.temperature is not sufficient in that case, you probably need to go deeper into JSON to extract that temperature value.
          I usually debug Jsonpath by testing preprocessing with those <IMAGE>
          Try to paste raw value you would get from agent and preprocess with different Jsonpath.
          • cgrenier
            • Nov 2025
            - name: zigbee-cgr
            - Key: temperature
